smae motor upgraded suspension and coil.The same coil and suspension on a level 5.
That`s not what I read on the DC website, Gap is tighter then the Lvl5 andit uses the Lvl 5 soft parts,it`s sit between the lvl5 and the lvl4.
Here are the facts:This sub was developed out of demand.
We were getting a lot of requests for something bigger than the LV4 but doesn't kill the gas mileage like the LV5 80+ lbs subs. We were moving a lot of hybrid subs that used LV4 motors with LV5 coils but we knew we could do better than that.
So we thought, everyone likes the LV5, It’s a fantastic sub... Lets use it as the platform for an in-between sub. We played around with a smaller version of the LV5 - That’s exactly what the XL is....
It uses all of the same soft parts of the LV5 with a smaller version of the same motor Just small enough to squeeze through the cut-out hole for a 10" driver. What was the end result? A great sounding high powered daily driver sub that can be used in or out of the competitive lanes. The XL has devastating lows and reliability. It quickly became our best selling sub!
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8”OD semi cup progressive roll spiders
• Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 1ohm , 1.4 or 2 ohm 3” 8 Layer Hi-temp Aluminum voice coil wound on black anodized voice coil former
XL
10"
12"
15"
18"
Mounting Depth
6.5"
7"
8.25"
9.25"
Mounting Hole Diameter
9.25"
11"
14"
16.75"
Motor Width
8.75"
8.75"
8.75"
8.75"
Weight
53lbs
54lbs
54lbs
56.5lbs
VC Diameter
3" Flat 8 layer
3" Flat 8 layer
3" Flat 8 layer
3" Flat 8 layer
Displacement
.18³ ft
.19³ ft
.23³ ft
.25³ ft
Magnet Weight
50lbs
50lbs
50lbs
50lbs
Power Handling RMS/Peak
1500/3000
1500/3000
1500/3000
1500/3000
Impedance (Ohm)
d.7, d1, d1.4, d2
d.7, d1, d1.4, d2
d.7, d1, d1.4, d2
d.7, d1, d1.4, d2
Sd
314.00 cm²
494.00 cm²
791.00 cm²
1159.00 cm²
Fs
39.03Hz
38.90Hz
35.60Hz
31.86Hz
Qms
6.07
6.51
6.98
7.25
Qes
.30
.31
.32
.33
Qts
.28
.29
.30
.31
Xmax
26mm
26mm
26mm
26mm
Sensitivity
86.6
90.73
93.70
94.77
Suggested Sealed
N/A
N/A
N/A
N/A
Suggested Ported
1³ ft
1.5³ ft
3.5³ ft
6³ ft
Level Five
LV5
A lot went into the design of this sub. We wanted an SPL sub without the drawbacks that some of the others encounter.
We had an idea, it was a sub with sick amounts of magnetic force but with a large gap
and cooling. This is something you don't see from other companies. But why would we be different? The answer is less coil failures and less re-cones. The only drawback (if it is one) you need a 73lbs motor to get the job done. Was it worth it? Yes it was!
The end result is a sub that has extreme amounts of output for the SPL lanes but reliable enough for a high-powered daily system.
When it was all done we ended up with a 73lbs triple stacked 1" slug, FEA optimized monster. We use a 8-layer flat wound 3" coil. Its available is D1ohm or D2ohm configurations. We also use upgraded multiple progressive spiders, upgraded cones, surround, lead wire, a cast basket and push terminals.
Key Features
• Dual 1ohm or 2 ohm 3” 8 Layer Hi-temp Aluminum voice coil wound on black anodized voice coil former
LV5
12"
15"
18"
Mounting Depth
8.25
9.5
10.5
11"
14"
16.75"
Motor Width
9.84"
9.84"
9.84"
Weight
78lbs
78.25lbs
80.5lbs
VC Diameter
3" Flat 8 layer
3" Flat 8 layer
3" Flat 8 layer
Displacement
.20³ ft
.24³ ft
.26³ ft
Magnet Weight
73lbs
73lbs
73lbs
2000/4000
20,000 burst
2000/4000
20,000 burst
2000/4000
20,000 burst
Impedance (Ohm)
d.7, d1, d1.4, d2
d.7, d1, d1.4, d2
d.7, d1, d1.4, d2
Sd
494.00 cm²
791.00 cm²
1159.00 cm²
Suggested Sealed
N/A
N/A
N/A
Suggested Ported
1.5³ ft
3.75³ ft
6³ ft
footer
