DC Level 5 M1 15" D1 Sub
its10v1
The Caped Rock-Head
8/10 Cos 10/10 Function
8/10 Cosmetic due to scuffs on surround, and a small hole. (All pictured below.)
Specs:
15" Level 5 M1
Mount depth: 9.5
Mounting hole diameter: 14"
Motor width: 9.84"
Total weight: 78.25lbs
VC diameter: 3" Flat 8 layer
Displacement: .24³ ft
Magnet weight: 73lbs
Power handling RMS/peak: 2000/4000 20,000 burst
Impedance (Ohm): Dual 1-Ohm
Sd: 791.00 cm²
Only tested it, I didn't mount it. Used a 12v @ 50A DC power converter.
No coil rattle, all bass.
Came from centergod79, He sold two of them to me, I really only need one.
@centergod79's listing said he thought that these were upgraded, not sure how to tell.
Sent one out to @SPLaudio today.
$295
+Actual shipping cost.
Buyer picks and pays.
[USPS/FedEx/UPS]
Light Scuff^
Small Light Scuff^
Small hole in Surround^ (approximately 1-2mm in size)
Does the slit go all the way through?
Unfortunately yes. I'm not going to attempt to glue it, tape it, etc.
It is extremely small. From my testing, I could not hear it flapping (then again it was on at most 450-500w RMS when I tested it.)
I don't know anything about these subs, other than they work, I don't even know what slit that goes all the way around that you guys are talking about, I never examined the subs, hence being why I sold them so cheap. I received these subs on a trade from a friend that bought 4 AB HD 15"s off of me. I gave him a little credit for them, and since I'm not a big fan of DC I just listed them and sold them for what I had in them. As far as any upgrades are concerned, darksoul is the original owner of them, he may know, I'm sorry I can't be of any help for you guys, I do like to help people, I just can't be of any about these particular subs, unless it were to pertain to rebuilding them, which is information I'm sure most of you already know, GLWS
The "slit that goes all the way around" does not exist.
There is a hole that goes all the way through the surround.
The hole is 1-2mm in size. I'm not trying to hold you accountable. I mentioned you because your listing said you thought they had been upgraded. (Also because I got the sub from you.)
Thanks for chiming in.
its10v1
The Caped Rock-Head
its10v1
Flint, Murda-Mitten(Mi)
its10v1
