DC 2.0 vs AQ 2200
i dont know where u got the aq for 365? but it is the same amp differnt case . iirc somebody was telling me u can literally strap the dc and the aq together .
Guy on here is selling it bnib.
oh ok , the way it reads in the title seemd like they are 365 from aq . i would say unless u like the dc case then the aq has my vote not to mention it has a better stle rca
I've never heard or seen either one in person so I'm just going on a whim here. I guess the AQ is best. Just don't know how much to.upgrade electrical for it.
i ran audioque and its the same as any other quality korean based amp , dont confuse aq with garbage type "good for the money amps" . with all that said all depends how u plan on running the amp? id say on stock electrical wired to 1 ohm u should atleast have one upgraded battery but untill u install it and see how ur volatge drops its hard to say .
jsut because they are both 2k amps from korea does not make them the same amp even if they are the same board not the same parts on the board. that being said both are great amps. With the dc you will get a warranty that will be backed up no questions asked . I've seen the 2ks run wired down to .34 with ease beating on them . Aq makes great stuff i run it check my sig but with dc your getting better warranty and a little better build amp .
this , also the efficiency on the dc amp is better than the aq ,hence a clean signal .dc is greater than 90% rated at 4 ohms and the aq is 86% at 4 ohms
and like a said a company that will back its warranty if somethign should happen worth its weight in gold. Altho those amps are tanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
lol easy guys i did not **** on dc ... the only reason i said that they are basicly the same is because i was told somebody did strap the 2 brands togther . also there was a test done a the dc 175.4 and the american bass 350.4 and its identical besides the case so its definetly a possibility .
i can promise you the amps are not "the same amp"
actually they are not the same , same boards yes but that is as far as it goes .the parts and layouts aren't even close .
NuckinFutz
NuckinFutz
Shreveport, La
murph
