Dayton spokes??!
standard or reverse? Usaully if the came off a rwd they would have a 5x4.5 (phord) and a 5x4.75 (chevy) bolt pattern adapters. The fwd adapters usaully come in 5x100 and 5x115 bolt patterns. The bolt pattern you probably need more than likley wont be on the adapters. You can get new adapters though for like usaully $200. From Dayton that would probably be twice that. How do you know they are Daytons? Daytons have the symbols and serial numbers stamped in the wheels. You probably have some chinas. Hope you didnt pay alot, usaully can get some 13" or 14" with tires for 4-5 hundred dollars. If you have reverse offset wheels which is more than likley what was on the blazer if they are 15" or smaller they will stick out and the car will look like a dune buggy, if they are 16" or bigger then more than likley they are standard offset and they make stick out 3/4" or so depending on tire size.
ThatChevyGuy
sue me, its a ford.
ThatChevyGuy
Georgia
ThatChevyGuy
