DataSafe Batts - Crazy Cheap!
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
PLEASE EMAIL RYAN@RAM-DESIGNS.COM IF SERIOUSLY INTERESTED
DataSafe "Batcap 2000 look-a-likes"
50ah - comparable to Batcap 2000, Kinetik HC1200, XS D1200, Stinger SPV44.
Dimensions: 7.75"L x 6.50"W x 6.9"H
Threaded inserts for easy hookup with ring terminals and 6mm bolts.
Designed for a quicker discharge rate.
All have been load tested and rest in the 12.8-13V range.
Current customer has one starting his 3.3L V6 Pathfinder.
$80 shipped for one
$150 shipped for two
Add $5 per batt if you're in CA/OR/WA on the west coast, or NY/RI/MA/NH/CT/ME in the northeast...just trying to save myself from getting burned on shipping charges.
Included in price
With these being quick discharge, would these be good for a daily setup? I ask because I'm needing a battery or two for more daily than anything else.
They work great as a secondary battery in a daily setup. Kangaroux on here is actually using one as a starting battery as well. When listening to music, quick discharge is what it's all about since you don't need to worry about supplying a lot of amperage for a long period of time(ex: bassrace run at full blast with a constant note).
I'm actually needing batts for daily.
Ive seen plenty of these cars with ten inch sub/ subs inverted/facing up and ported to the rear.. even a single 12
725
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
Kangaroux
    Jun 18, 2024
Dan Medina
    Jun 17, 2024
