D1 or D2 Voice Coil?
  • 7
get two d1 subs. wire each sub to 2 ohm by connecting negative to positive and negative to positive on each sub. this is called series. then, run each amp off of its own set of rca cables and power wires, and you will be running each amp at two ohms producing 1500 watts per amp. the higher the ohm load, the more efficent you will be, which means cooler amps and more power. the bdCP amps produce the same amount of watts at 1 ohm as they do 2 ohm, so you might as well have a higher ohm load to increase efficiency without losing out on any power.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
629
I looked at Crutchfield. Sure enough, dudes right up does say it. I even looked on YouTube. There's only 1 review on the m7 subs, but it's...
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
961
njknittle
njknittle
PA
njknittle
