Cutting aero port help
You should consider about half of the flared portion of the port still part of the length...so measure the total length of the flared portion/2 and add it into the equation and then add in the tube part and make it 13ish" total (though Id cut it a bit long...38Hz is too high for my taste)
EDIT: actually there's no need to devide the ports flared section by two..because there is a flare on the other end so just adding in the total length of one would compensate for both
I have 2 4" aero ports in a 3.1 cube box... to get a 38 hz tuning it says
Straight Length Port required 12.20
Flare Length Port required 13.20
Do I put the mounting flare end on it, then measure from that down 13" and cut off the excess, or just measure 13 inches on the straight tube without flares on...
If you want it tuned to 38, the total length needs to be 11.9 inches.
Hey gary, I got them cut in our woodshop, they are an overall length of 14 and 3/8ths iirc , looks like its a little long still... But I did notice an increase in overall loudness and it still hits the lows very well... I will try to get back in there and cut em down to 12 inches...
If the overall length is 14 you are tuned to 35 hz, Thats were I wanted the tuning. Thats an overall good freq. for a lot of music. If you want 38 hz, overall needs to be a little under 12 inches total. Anywhere from 11.5 to 12 will be good. Keep the pieces that you cut off the tubes... you can use them to tune it up higher if you ever want to compete.
Twistid
Twistid
in a space out of sound
banginAltima
