Cut out hole Size for 07 XXX 12
Product Dimension12"
Mounting Depth - 12.75"
Mounting Hole Diameter - 11.5" ----- so is that the size of the whole or is it
Overall Diameter - 13"
Bolt Hole Circle - 12.25" ------- or is this the cut out size?
Motor Width - 10.5"
Motor Depth - 5"
Basket Depth - 7.75"
Displacement - 0.24 cu. ft.
Weight - 72 lbs
bolt hole diameter is exactly that, the diameter of where the screws go for mounting, like stated, what you want is the mounting hole diameter, and overall diameter is if you wanted to flush mount it
Jerod187x2
Langley
iamamp3pimp
