Custom SPL fuse block
i cant wait to get started on this monday mornin! so BEN other than the aluminum that you suggested what else do I need other than the fuses them self?
Bolts and nuts to secure the ring terminals //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Another reason why I like these custom blocks. Once the wire is attached, there's way less chance of wires popping out:).
If you want some of the short metal screws I can give you a ton of them. My dad gets them free.
definetly
Is it legal to use slow-blow type fuses?
You have a 94 Ranger? Sounds like you have the exact same truck that I do. The older ones like ours are about 1.5 - 2 dB louder than the new trucks.
All of the fuse types are listed in the MECA rules, which pretty much rules out slow blows.
I use midi fuses. Apparently im the only one in meca who does //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I may have to borrow some of your 30's / 35's to see what I can do with them.
I have some littelfuse and knukonceptz midi's and agu's walked all over them hard.
I couldn't even get a full tilt burp off a pair of 30 amp midi's.
But if you want to try them out I can bring them down to casper.
werid...you've seen what mine can do on two 150's ... maybe its just the 30's that ****?
Could be just the 30's, who knows. What I do know is that the 30 amp agu's are WAY stronger. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You ever clamp your setup to see what your current draw is?
What about 40 amp AGU's? I will be running (2) of these to a 3000d.
jshak07
148.4 and climbing
jshak07
louisville
snoopdan
