Air motion tweeters sound pretty good. The ppi set uses them. I have a pair of dayton b652s with the AMT tweeter and they sound a lot better than most soft domes. Super rich sparkling upper end with zero harshness. Gets loud too.I did hear those are the BEST components for the money.
Do you think they'll keep up with sub stage is the question?Air motion tweeters sound pretty good. The ppi set uses them. I have a pair of dayton b652s with the AMT tweeter and they sound a lot better than most soft domes. Super rich sparkling upper end with zero harshness.
if you bridge the ppi to them, the question is if your subs stage can keep up with them.Do you think they'll keep up with sub stage is the question?
I like the way you think //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I would love that feeling honestly.if you bridge the ppi to them, the question is if your subs stage can keep up with them.
Some location are pretty interchangeable between small midranges and tweeters if you want to do a 3 way active front. Best thing to do is get double sided tape and have the tweeters stuck on to possible locations and see how they sound. You'll also want to have them either angling directly at your ears (on axis) which is usually the best or 30 degrees off axis or 60 degrees off axis (which just means pointing 60 degrees off from directly firing at your ears.) .Can some one link me to a diagram or a explanation for what is being talked abt here id love to learn a bit abt speaker relocation for better sq
What type of processing do you have?Yeah I love SQ for daily. However I like choking, painful bass as well. Good thing there's always a sub level i can lower down the bass to blend with the mids(yes you can do that even with 4 18s...) along with having two custom EQ settings, one for SPL, one for SQ. Having the Best of both worlds is the sh*t!
I had a soundstream harmony, enjoyed it when i did have it in running 3 way active, however since i switched out my laptop, I have no way of connecting to the ppi to tune it since the new one does not have a dedicated com port on the motherboard.... fking *****...What type of processing do you have?
Dang, my buddy has some 3 ways and I forgot which ones but he just got a Helix dsp I think in and loves it.I had a soundstream harmony, enjoyed it when i did have it in running 3 way active, however since i switched out my laptop, I have no way of connecting to the ppi to tune it since the new one does not have a dedicated com port on the motherboard.... fking *****...
I have to use the 80 prs for 2 way active front now. Front stage getting some revamp to match the 4 18s comming in. New amps, two pwx 10s with sonotubes in the doors and maybe an alpine DSP in the future when I go back to 3 way active and then i'll do some 4 inch midranges in the dash.
