its gonna be in a 99 626 MazdaGood he does amazing work.
---------- Post added at 11:07 PM ---------- Previous post was at 11:07 PM ----------
What vehicle and a square port no.
They charge a quarter a cut at Lowes.Buy a design. Get a cut sheet take to lowes tip saw man $20 bucks he will make all cuts go home glue and screw together and rent or borrow a jig to make the hole and ur good to go. U can build you own for well under 100 bucks... Wood 30-35bucks 20buck tip, $6 glue, $4 screws. I know someone around u has a jig u can borrow for 5 mins.
Yea and u will get a box that may or may not fit together. Big sign says cuts may be off. Tip the man and he will take his time and get it done right.They charge a quarter a cut at Lowes.
Thats what Im doing, he's working on the design right now and Im happy with the priceTalk to pro-rabbit, he is starting to do DIY enclosures where he cuts and sends you all the stuff, all you need to do is assemble.
I like birch over mdf most of the time, but it does not alter the price 99% of the time. Most logistic companies use "bulk weight" which is derived from the size of the item.I can build you a simple slot ported birch box for $120+shipping. Much lighter so less expensive to ship.
That is because you can fit a Geo Metro inside your enclosure. lolThats what Im doing, he's working on the design right now and Im happy with the price
What subs? Depending on the actual size needed I can get you a DIY kit with in that price range I think.can someonemake me a good simple and cheap box for 2 12s for around 135 shipped ? Or would it be cheaper for me to get a box design and get home depot to cut it out for me ? I don't have the time to make a box
this and it works bring your tape measure if they mess up they will get it right from another sheet then...if not enough left from your sheet...theyve done this for me before....right there saved another $35 so well worth tipping the guy a $20Yea and u will get a box that may or may not fit together. Big sign says cuts may be off. Tip the man and he will take his time and get it done right.
i need to switch to birch myself just so use to mdf^^^ Birch FTW... Will never use mdf again..
