Custom Big 3 kits in OFC and CCA
RAM_Designs
SketchUp Master
21,735
Rockwall, TX
Email at Ryan@RAM-Designs.com to order with your measurements ready please. I DO NOT RESPOND TO PM'S.
1/0 Big 3 kits using black Audio Technix CCA and OFC wire. FIRST 10 ORDERS GET A FREE AUDIO TECHNIX DECAL!
These will be made using Audio Technix CCA and OFC wiring, which is some stout wire for 1/0...barely fits inside the 2/0 ring terminals I am using. The ring terminal bolt hole can fit a 3/8" bolt. The connections will be crimped via a hydraulic crimper to ensure that the wire will never come loose. The connections are then heat shrank with adhesive-lined heat shrink tubing that will not budge once shrank. All in all, it makes them look very clean, and the black on black look keeps it stock looking as well.
$49 shipped for CCA
$69 shipped for OFC
Included in price.
my 03, was around 4' for the alt to battery.. 2.5ft from bat to motor depending on where you ground to.. then another 2-3' from bat to frame depending on where you ground at... I would do 5' + 3' + 2' .. but best thing to do is measure out the car for where YOU want to ground and run the wire around/from/to
so u suggesting for my impala 5 t 3 t 2
Its what I used on my 03... but honestly there might be a little diff between what I used and how you would run it yourself.. maybe a foot or so... depends on how and where you want ur ground points mainly.. I ran my alt to battery cable around the firewall to fenderwall.. i ran the frame ground to the bottom frame.. and the motor ground to another point on the motor i can't remember where..
Thanks for the help on the topic.
Really want a kit but i got a quick question for ya Besides this kit what else would I need to buy fuse blocks? And what's all that gunna run me?
You don't have to have a fuse block/holder etc.. but it would not hurt to have one between the alternator and battery run.. some people swear by them some don't.
it is all a matter in how much you trust your wiring skills.. ebay has the holders for a few dollars to 30$
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
adamrali
