Crunk Times, My friend.....Crunk Times
Your amp needs to be ~ 13V min. if car is on.
Watch it to see if there is voltage drop on the high notes.
Low voltage can cause problems
And I just stick the leads to the power and ground of the amp to test this?
Would I possibly need to check the current too?
And how do I check the resistance of the subwoofer?
Checking the positive and negative is checking the current //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Most amps if they drop below 12 volts go into protect.
So what's the difference between measuring the voltage and current?
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
▼)Ñ╩fZΣµ&
    Jun 24, 2026
    Jun 24, 2026
