Crossovers giving off light at high volume? Why?
budget76
fawkin' newb
Well, I felt like turning up some rock last night, instead of just the bass, and when the volume was at about 40 of 50, I noticed a flashing light under my dash. "what could that be? Only thing down there is my crossovers?"
Pull over, and they're flashing. They are in a clear casing FYI. It looks like the light is coming out of a fuse/mini light bulb looking piece inside the casing. Is this normal, or is this like a clipping indicator or something like that? I'm guessing it's just from the power running through?
FWIW my front comps are a little mix of this and that. Focal 5.25 mids, cheap MTX tweets, and DB Link crossovers. My guess is they're seeing about 60 watts at this volume. Off a nice Sony amp, but it's still an Xplod, so it's not that nice. Built in EQ and **** though, does it's job well. The sound never sounds bad, still as clear as I'm going to be with my hodge-podge mix of components, which makes me believe nothings wrong
thanks for any input.
its the protection on them, instead of sending the power to the comps, it glows the lights
which means your not doing something with the amp settings, recheck the settings on the amp and eq on HU
My old kicker crossovers used to light up when givin enough power
resolution crossovers and i think the new ss kicker crossovers are the same
so it's not a bad thing, but not a good thing either? Either way, next time I have time to play, I'll turn down the higher frequencies a little on the EQ for the fronts. I RARELY have it up that high, maybe once a month at most, so i'm not too worried. Glad to learn something new. Never knew they had a tweeter protect built in.
thanks guys
it's a bad thing. means you have DC current coming out of the amp. DC = distortion.
edit: but that's what they are there for, to help "catch" (for lack of a better term) that distortion. If they only blink every once in a while, you're fine. If it looks like a strobe light or a constant glow, then you may need to look further.
It doesn't mean that there's DC going to the comps. The lights in your house run on AC and so do the lights in the crossover. It only means that the voltage is high enough for you to see the light.
oh yeah? so that means the lights in my dash work on AC current too?
It's a DC distortion filter.
If you apply enough voltage, AC or DC, to a light bulb, it will light. I could run an unclipped pure sine wave to those speakers and get the lights to come on quite easily. A the same time I could apply low voltage DC to them and they wouldn't. You don't know what you're talking about so just stop. An yes, if the lights in your dash are incandescent, they WOULD light with AC doesn't mean that they ARE but they WOULD. LEDs are a different story, but they will light off AC as well but only one half of the cycle.
My understanding of the lights has always been that they are a buffer for DC current coming out of the amp. And everytime i've tested a comp set that is lighting up, there has been DC coming from the amp, mainly because of low voltage to the amp, or poor ground.
Do you disagree that this is a purpose of the lights, as a protection circuit/buffer to prevent damage to tweeters (mainly)?
that will be $40 my btc wallet is 5748384758585854445... jk! :ROFLMAO:
So I did a tone test and found that the tweeters start making sound at about 1500hz which would put the crossover several thousand hertz above...
808
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
400
371
budget76
fawkin' newb
budget76
Monmouth County New Jersey
JRock10
maylar
    Jun 2, 2024
    Jun 1, 2024
