Cross over on headunit or amp?
ohhh my
Hi Guys,
I'm running an Alpine 9835 headunit and an older Apline V12 2 channel amp for my bass.
Which one should I let do the filtering of the low pass? My headunit has a built in cross over which I have set. My amp also has a low pass, high pass or full option that is currently set to low pass only.
Is this the correct way or should I set it to full and let me headunit do all the filtering?
you can always do both if you want to be sure...if you have a better Hu (i.e. 880) then I would go with the HU but a lot of times it seems safer with the amp
To be sure?! That's the dumbest thing I've ever heard. Having both filters on can and will affect the slope and phase of the drivers which can have a negative effect on sound quality.
For ease of use and changing while driving, go with the headunit. For more precise dialing in, then use the amp (by precise, I don't mean trusting where the amp says it is set it but rather you have more options).
True, that's something I didn't point out. My HU at least, goes in 10 or 20 hz intervals. If you want something between, you need to use the dial on the amp.
ohhh my
ohhh my
so cal
rollerdj
