Crazy Question... but...here goes
yeah cut how long the wires need 2 be... put one end in a vise or get someone else to hold them tightly... and put the other end of the wires in your drill like you would a drill bit... and twist away
i've never done this but i assume its pretty simple. just get three wires of the same length. make sure all 3 wires on one side is held together with some tape and make sure to tape it onto a hard to move object (desk/) and the other side of the 3 wires be taped onto the drill with some more tape then just turn on the drill.
there could be an easier way to do this but i came up with this from the top of my head so try it if you want.
You should be able to just clamp/chuck the wires into the drill like you would a drill bit.
he right except you will have to cut the wire longer than you need. when the wires twist up they will shorten considerably.
it is also let tideous to run 1 wire at a time with a fish tape than to run 3 wires at once with a fish tape. It is also suppose to help with the noise rejecting cababilities.
Hold the wires in your teeth, and point the drill at your head. Then pull the wires through your ear with the tip of the drillbit. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
* Please don't do that.
plazman
plazman
USA
maylar
