Sold Crazy cheap Stinger SPV70s $75 and SP1700s $125
bumpin buick
Science is everything
I just picked up 6 of these from a shop not to far from me. The shop owner has roughly 40 of them left and also about the same amount of SP1700s. I only purchased the SPV70s because that was all I needed and have pics of some here for everyone but I saw some SP1700s and they looked near flawless.
Some of the batteries were slightly used but show no signs other than some possible scratches on the black metal holder. Other than that they are perfect. The shop owner does not go to forums due to his busy schedule but has asked me to see if anyone else would be interested in them.
$75 each = SPV70
$125 each = SP1700
Prices do not include shipping. Please try and find quotes on your own if possible as I do not plan on getting a hundred people quotes. The batts weigh roughly 60lbs and the box dimensions are close to 16x8x10. If anyone has any questions please let me know. I am not in this to make a profit as I am selling these batts for what he sold mine to me for. The owner just said if I can sell some for him he will help me out with some accessories if needed. Thanks
And for those of you constantly asking about comparisons...
This is the Specs on the SPV70
# Internal resistance
# 5 Second Cranking 1050 Amps
# Weight 57.3 lbs
Constant Discharge Capacity at 77 degrees to 10.50 Volts:
# 20 hour rate: 3.5A/70Ah
# 5 hour rate: 11.9A/59.5Ah
# 1/2 hour rate: 87.5A/43.75Ah
# CCA: 875 Amps
DIMENSIONS
# SPV70 6-7/8" H x 13-3/4" W x 6-1/2" D
# (Add 5/8 to height for battery post)
General POWER Series Specifications:
# Temperature Range: -15 to +50 C
# Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
# Maximum Charging Voltage: 15 Volts (Cyclic Use) 13.8 Volts (Standby Use)
SP1700
* Maximum Peak Discharge of 3500 amps
* 5-Second Cranking Output of 1700 amps
* Cold Cranking Output of 1200 amps
* Nominal Capacity of 72 Ah (C20 rate)
* Absorbed Glass Matt (AGM) Dry Cell Technology
* Gold-Plated Top Posts
* Internal Resistance: 0.0035 ohms
* Dimensions of 6.5" L x 13" W x 7.4" H
These are good batteries I use to have the smaller one's back when I first got into car audio. Now you can stop asking bumpin how it compares against such and such battery and just compare for yourself.
bumpin buick
bumpin buick
Appleton, Wisconsin
Abel
