correct way to wire? picture to explain.
And the last part of that statement is incorrect, if u wire both coils together in a parallel from a DVC4ohm sub its true that u will get a 2 ohm load, but if wired in a series than it will be a 8 ohm load.
An example would be obtaining a 1ohm load with 4 4ohm DVC subs. The lowest impedance you get using both VC's is 2 ohms, so can you simply use 1 VC to get 1 ohm load?
FYI, I've never owned a dual-sub setup. I would research it before I did, trust me. For reasons like this...
it's not even just a dual sub setup, it's just a single sub with DVC. kind of the same principles if the dual subs have SVC tho //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif and I'm not trying to insult u, im just stating facts.
I was speaking hypothetically about a DVC. You even adressed that I needed to check the owner's manual of a DVC sub. Now that post is gone...//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
You're seriously confusing the heck out of me. I think you're trailing from what I was originally asking, or you just didn't understand what I was saying?...Let's leave this issue alone before my head explodes. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ya i really didnt get ur original question, i just saw 4 ohm DVC, wired in parallel would be 2 ohm load (true) but if using just 1 voice coil it would be 1 ohm ( which its the false part I stated)
I love you. ?...(no ****)
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
pitbull12888
waxhaw,NC
bikinpunk
