Assuming I translated that foreign language correctly, 'welding cable' (the common term here for wire used on the 'stinger' of a welding system) has more than 133 strands. A lot more.its welding cable than use its not that stiff now and day flexaprene welding cable ftmfw
stop being a douche bag dawg no one likes on mkay im not even american so i think i type fairly wellAssuming I translated that foreign language correctly, 'welding cable' (the common term here for wire used on the 'stinger' of a welding system) has more than 133 strands. A lot more.
You think wrong, dawg.stop being a douche bag dawg no one likes on mkay im not even american so i think i type fairly well
Wait, isn't it true that more area= less resistance = less heat = better conductor?Conductivity is a property of the metal, not of the area or number of strands. The area increases the current handling and more strands (of the same area) increase the flexibility of the wire.
Yes, this is technically true. For 99% of cases if you have your wire sized correctly you won't have any change in conductivity because the temperature change would be negligible. If you are comparing 2/0 with 133 strands and 2/0 with 1000 strands and they both have the same area, their conductivity will be the same (or so close it doesn't matter).Wait, isn't it true that more area= less resistance = less heat = better conductor?
