Cons of Hifonics bx1500d
Yea LED light is very nice but it can attract unwanted attention.. I guess it only applys to people with hatchs and SUVs with plain view to the trunk.
Mine takes 2 60 Maxi fuses.
It came with 2 60s, but I have read on 2 different forums that you can call HiFonics and they'll tell you it was a mistake, they are supposed to have 2 80 amps in there... and they will ship them too you.....
If I remember, I'll e-mail them on Monday and find out for sure... I'll post my e-maiil to them and their response....
Actually, as the frequency changes, the impedance of the sub changes wildly. With normal music, it can go REALLY high.
From what I understand... your speaker may be a DVC 2 ohm, in parallel creates a 1ohm load. But actually your amp will see a fluctuation of 1ohm during certain frequencies. So at times the amp might play a 30hz freq and see a .75 load any other times it can pop up to 1.25 etc... so its not actually playing 1ohm straight through.
Not to mention, no ones resistance on their sub is 1.00 ohms. I've got an Adire Brahma, DVC 2ohm. Each side actually registers 1.75 ohms on a volt meter.
I suppose this is also a way for the sub to squeeze out a few more watts from an amp, kinda nice.
still waiting for that email
I agree with the brightness thing. I have mine set to black out in 5 seconds, lol. Never noticed the crossover issue since my dsp handles...
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
ssj2xxgotenxx
The Chan Man
ssj2xxgotenxx
Bay Area
smullen
