connections
nope...if they are 6 ohm subs and you wire them in paralell it will creat a 1.5ohm load...which is above the one ohm that your amp is stable at....and if they are 12 ohm subs...wired in paralell it will create a 3 ohm load if im not mistaken....all of these figures are assuming that they are dual voice coil subs and they are wired into a mono load...for a sterio load it will be a little diff...sterio will produce 6 and 12 ohm loads......good luck
mono load1.5(6ohm sub) or 3(6ohm sub) ohm load
sterio load 6ohm(6ohm sub) or 12(12ohm sub) ohm load
647
CustomMaxima97
CustomMaxima97
Somerset, MA
Larrydehp920r
    May 24, 2024
    May 23, 2024
