connections
  • 3
nope...if they are 6 ohm subs and you wire them in paralell it will creat a 1.5ohm load...which is above the one ohm that your amp is stable at....and if they are 12 ohm subs...wired in paralell it will create a 3 ohm load if im not mistaken....all of these figures are assuming that they are dual voice coil subs and they are wired into a mono load...for a sterio load it will be a little diff...sterio will produce 6 and 12 ohm loads......good luck
mono load1.5(6ohm sub) or 3(6ohm sub) ohm load
sterio load 6ohm(6ohm sub) or 12(12ohm sub) ohm load
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
383
CustomMaxima97
CustomMaxima97
Somerset, MA
Larrydehp920r
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
Latest topics
