connecting runs of 4awg
well the distance from the battery to the fuse is arbitrary.
as long as the piece of cable between the batt and fuse is protected and will not be damaged/shorted it can be longer.
you want to keep it as short as you can but making it a bit longer isnt going to kill you as long as you are careful.
~Magick_Man~
solder the shiz out of the 2 together then lots of electrical tape around it or get a dblock then you can run multiple amps if ur lookin for a dblock hit meup
BLD 25
BLD 25
Carbondale, IL
jdawg
