Connecting my new alt
when im going to install my 170a do i keep my stock wiring and do the big 3 or do i have to use 0g to connect the 170a alt + do the big 3?
You can keep the stock wiring as long as you do the big three. Doing the big 3 plus adding 1/0 guage will just make it like you did double the big three, which isnt really needed.
Also, would not fusing alt + to batt + blow up my car? It should be bad, fusing is just recommended just in case, but what would happen if i didnt fuse..
I didn't fuse mine and I have no problems. Only reason I would fuse is if you have a long run from batt+ to alt+.
chinny
Banned
chinny
Miami Dade
chinny
