I read the 12volt.com thing and I still don't understand the RMS. If there is 550watts coming from the amp with 2 ohms and whatever it is at 4 ohms but im going to assume its 275 because thats what 1100 divided by 4 is. Lets see if I can put two and two together, I just found the specs on my subs which are:
A friend of mine has 2 Kenwood KFC-W3003 subs. Here are the specs from the manual:
Single Voice Coil
Nominal Impedance =4 ohm
DC resistance =3.34 ohm
Voice Coil inductance =1.10 mH
Piston area =.0491 sqm
Force factor =9.80 Tm
Volume acoustic =82.84 liter
Compliance =2.925 cu.ft
Moving mass =100.1 g
Fs =32 Hz
Qms =10.45
Qes =0.70
Qts =0.66
RMS =160W
Peak power =600W
Xmax =9 mm
Displacement =0.141 cu.ft
Mounting depth 5-5/16"
Weight of magnet =42.3 oz.
Voice coil diameter =2-9/16"
It says the impendence is 4... im guessing thats the ohm of the sub... if the subs ohm is 4... does it need 4 from amp? if so should I have 8 ohms to do 2 subs or is it something else. because i don't understand it.. the amp now that im told by the specs says it isn't capable of 1 ohm, what does 1 ohm mean does that make it super powerful?
Single Voice Coil
Fs =32 Hz
Qms =10.45
Qes =0.70
Qts =0.66
RMS =160W
Peak power =600W
Xmax =9 mm
