KENWOOD KAC-8152D CLASS D (Questions)
gotgohan
I was wondering... will this AMP conflict with my kenwood W3003's the AMP is of course 1100 watt, and the subs are 600 watts each. I dunno anything thats going to happen with this combo. I am a superb nub at this, I can return the amp back if It isn't a good buy.
1100 is max, yu need to look for rms, in this case is 550 x 1 @ 2ohm. and 300 x 1 @ 4 ohm. i dont think it is 1 ohm stable...so youll probably be starving your 600rms subs if anything.
youll probably need to find a 600x2 amp or 1200x1
Here's the stats the seller gives:
Class-D Monoblock Amplifier
Bass Boost Level and Frequency Remote Included
Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
Variable Input Sensitivity: 200mV - 5V
Phase Shift: 0° / 180°
Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
High- and Low-Level Inputs
1 Ohm Stable
RMS Power Handling:
300 watts x 1 chan. @ 4 ohms
550 watts x 1 chan. @ 2 ohms
Preamp Outputs: 1 Pair
Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
Dimensions: 15" L x 11-5/16" W x 2-3/8" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels: 1 - Mono
RMS Power (4 ohms): 300 watts x 1 chan.
RMS Power (2 ohms): 550 watts x 1 chan.
RMS Power (1 ohm): Not Stable
Bridged RMS Power: Not Bridgeable
Peak Power Output: 1100 watts
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: Not Bridgeable
THD @ Rated RMS Power: 0.5%
Speaker Level Inputs: Yes
Amp Preamp Outputs: Yes - 1 Pair
Built-in Crossover: LP (50 - 200Hz), Subsonic (Off/15/25Hz)
High-Pass Crossover: N/A
Low-Pass Crossover: N/A
Subsonic Filter: N/A
Signal-to-Noise Ratio: 96 dB
Channel Separation: N/A
Bass/Gain Remote: N/A
Fan Cooled: No
Fuse Rating: 40A x 1
Warranty: 1-year SE
Well what does this ohm stuff mean.. it says 550watts at 2 ohms.. does that mean its 1 ohm per ohm or something? does that mean its splits up if ih ave two amps lol
so you have 2 subs each at dual 4 ohm correct? you can either wire them to 4 ohm or 1 ohm. but since that kenwood amp is not 1 ohm stable, then that option is out. therefore you can only run at 4 ohm.
if u get that kenwood amp...you will be pushing 300 x 1 at 4 ohm. divided into 2 subwoofers, youll get 150 rms a piece. as i said before..youll be starving those 600 watt rms subs.
gotgohan
gotgohan
Illinois
soul05
