Confused on how to get the most out of my subs and my amp...
HardcoreBob
Dallas
I'm doing my best to understand how ohms and my subs and amp work together...
I have two, 10" DVC 4ohm subs 500 watts rms each...
I understand I can either wire them to present a 4 ohm or 1 ohm load to my amp...
I thought my amp was 1ohm stable, but reading these stats, I guess that's not the case...
Is this 1500 watt amp enough to push two subs well since I can only wire up to or in the 4ohm configuration?
It is my understanding that I take the rams of my speakers "combined" which is 1000... is 750 going to push them well?
Sent from my iPad using Tapatalk
yeah more power be better but what subs? whats the db and mms specs? maybe they aren't that "heavy"..
So I’m better off using this, my other amp? It is capable of 500 at 4 ohm, is that going to give me some reasonable power?
That PPI is a 4 ch amp. Better off getting an amp 1 ohm stable to power your subs. Doesn't have to be an expensive one either.
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Dayuuum!! LOL. Going CHEAP sometimes doesnt pay..LOL 💩 💩
13
Hey guys I'm new here I'd like first and foremost that I'm not greenhorn but I haven't been an installer for 10+ years either. So the issue I am...
You can always get a bridgeable 4 channel, too, instead of a massive 2 channel.
829
HardcoreBob
HardcoreBob
Dallas
Boomin_tahoe
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
