Confirming Box Design
FI15INCH
Hey guys,
I just want to clarify or get a another view from someone else about the box I am about to make. Its for a 15" Fi BTL Sub. It going to have 4cuft. tuned to 35Hz.
(Calculations done by: BKOLFO4)
The box with a slot port will need to be 17" tall in front, 14" tall in the rear, 31" wide, and 23" deep.
The slot port will be 12.5" x 4". You will run it into the box until it is 4" from the back wall, and then turn and go 2" parallel to the back wall.
(Designed by: BKOLFO4)
Thanks for any input,
Curt
Hey guys,
Curt
Well, your boned, the height of the port is going to slam into the interior top of the box if you plan to use 3/4" MDF to make up the port wall elements.
Just do a 5" x 10" and you only need the top port wall at 5.75 x 21.5" & the port side wall at 10" x 16.5" and your done.
FI15INCH
FI15INCH
New Jersey
Mr Cabinetry
