Cone Travel
i would have at least 3". here is a cool way of angling the front baffle so you have more clearance, and also so you have more mounting depth for the magnet.
show_image.pl
where did you get that info?
Out of the link you posted - which was the owner's/installation manual. Said manual happens to contain the T/S (Thiele/Small) specifications of the DAT M6 subwoofer. According to the manual if you have the dual-2 M610 then the Xmax(mm) is 15. If you have the dual-4 M610 then your Xmax(mm) is 16.
Xmax(mm) = maximum excursion (cone travel) measured in millimeters
Xmax is usually accepted as the point where the BL is 70% of it's rest position.
Xmax and maximum excursion are two different things. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
blowsoot
blowsoot
Los Angeles, CA
skmfkr
