? concerning dual ports for a single sub
i have a box similar to what you are talking about and i think it looks nice. It's 38 wide x 14 tall x 14.5 deep. here's a pic.
Oh, and it's Jaeger //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
My bad...
Noah = Spelling Nazi???
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
38.5 wide x 14.5 height x 16.5 width - .75" of mdf you have a good: 4.175cuft to play with. so if you go with a 2.5cuft enclosure tune to 32Hz with 2 ports each port being 13" x 1.5" x 37.23" that will give you 39sqin of port area per port. more then enough to keep port noise down. and thats an even smaller enclosure 3.727cuft. so you still have room for sub displacement and lots of bracing to make the enclosure super solid.
how q sound at 30? is 2.2 to small in your opinion, would u like to have lets say 2.5?
Mike
also it doesn't look bad either
I have a Q at 30 hz in a 2.5cube box and I absolutely love the low end. I'm guessing it could be louder, but I would rather have it quieter up in the higher frequencies and dominate the lows.
well here the plan, i have a single 12" fi q, and ill be tuning around 28 - 30 hz. I have a big trunk car, and really want to take advantage of its width. so i was going for dimensions like 38.5 wide x 14.5 height x 15.5 - 16.5 width. now i really want to use this big width but i think it would look akward having a port on only one side and the sub far away. i was thinking of having my fi q centered and run 2 L ports to the front sides of the box
Something like you see with dual sub setups
Now here the ?
How would i go about figuring out how much width and length and area i would need of the port, i have single port plans of a 2.5 cu ft. box @ 30hz after displacements and stuff and i have a port area of 40, port length of 39 and port width of 3.25, how would i turn this into a dual L port design, im pretty sure you dont just divide by 2 :).
would a maze port actually be better then an L port for going for a dual port on a single sub?
Help me out and guide me, if one of you guys wants to work on one, use the dimensions above
Mike-
tuning this isnt a problem for me duder.
I've done them before, and actually prefer them for single sub setups
well i wanted to get my plans, so you didnt have to use ur time :), seeing how ur already doing alot, it one thing out of the way.
But if u insist and its your speciality pimp, sending pm right now.
Mike-
theothermike
I HAVE NO LIFE, CA = LIFE
theothermike
Tampa
theothermike
michigan born
    May 14, 2026
michigan born
    May 14, 2026
