Computer help!!!!!
Look for the vista driver then modify it to work on XP might take some time. Might be able to find a forum where someone has already done the grunt work for you. but, you might think about just giving him a laptop with lenux on it.
lol
Thats an idea
But
He doesn't know what a hotkey is.
Get on there on your computer then download the driver to a usb stick plug it into your laptop. install the driver.
Thats what ive been trying to do but i haven't found one that works.
It's not hard to get a copy of 7 or vista. And you can update with them as well.
But a legit copy is what i want
If it's your lan driver, download this, put it on a flash drive, run it on your computer
Driverpacks is a nice little tool that has a ton of drivers in it and tries em all til one works for you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I wouldn't use it for graphic drivers (i have another tool for that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif but it's great for ethernet drivers
DriverPack LAN 11.01 for Windows 2000/XP/2003 (x86) | DriverPacks.net
Cant remember if thats only drivers in that first download or if it has the app in it too
if not heres a link to the application
DriverPacks BASE 10.06 | DriverPacks.net'
But honestly, why run xp when you can run either 7 or ubuntu? or both?
Also if it was blue-screening, did you run any diagnostics or just format? Could be your hard drive has some failing sectors and might happen again (if thats the case then sooner than later)
If it's your lan driver, download this, put it on a flash drive, run it on your computerDriverpacks is a nice little tool that has a ton of drivers in it and tries em all til one works for you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Not my comp. Im giving it to my cousin who doesnt even know what linux is. He wanted me to put xp on there instead of just trying to fix the blue screen. I just had no idea i run into this. Thanks for the link tho ill try it out.
Well like I was saying, most blue screens nowadays on OEM computers are "usually" results of hardware failures, as software has become fairly stable in recent years.
I'd run a hard drive scan that scans sector by sector, if it came with vista on it there's a 50/50 chance it has a hard drive diagnostic utility built into the bios or boot menu, go to boot menu on boot (usually f12) and see if there's an option for it, if not try going to bios (usually called setup, can be f2, f8 or del usually) and see if there's an option there, don't change anything in setup
Just saying, i'd hate for you to do all this **** then it just blue screen when you give it to your cousin because it ran into the same bad sector again =P
You may be able to "Fix" a blue screen, but you're only fixing the symptom, not the cause
(Yes I know, you can get a blue screen from driver's or viruses, but OEM computers don't typically run into the same driver problems that custom builds do nowadays, and it's always good to rule out hardware..)
Well like I was saying, most blue screens nowadays on OEM computers are "usually" results of hardware failures, as software has become fairly stable in recent years.I'd run a hard drive scan that scans sector by sector, if it came with vista on it there's a 50/50 chance it has a hard drive diagnostic utility built into the bios or boot menu, go to boot menu on boot (usually f12) and see if there's an option for it, if not try going to bios (usually called setup, can be f2, f8 or del usually) and see if there's an option there, don't change anything in setup
I gotcha now, i misunderstood earlier.
But now im at the point i just want the frickin thing to work, but im beginning to lose faith in my abilty to do that.
Download driver genious or driver magician and run update on the programs then it will search the net to find the drivers you need to install do one by one until they are all installed. U can download these via filestube.com or extratorrent.com
Soo... you want him to install a program on there, run update on it, then the program will search the net for a lan (INTERNET) driver?
The program I sent him will work fine for it, without the risk of getting spyware/virus that most driver programs do, without a flashy screen as well.
Savstyle
Savstyle
Fresno
benzmansl65amg
vegang
vegang
