computer geeks help me
noob with an RS
i poop on you
ok my computer just crashed after trying to overclock it. when i turned the computer back on, stable, the monitors settings were all messed up. i had to use the OSD on the monitor to set the settings back to how they were. i noticed that when i went to my OSD it displayed the frequency which my monitor was truly running at. i noticed that it was 59.9 hz and that it would not go over even though my refresh rate is at 100. this reminded me of counter-strike.. when i use to only get 60 frames maximum (when i knew i should be getting more) and turning off vertical sync in the videocard's drivers would get rid of this maximum. is there a way to make my monitor run higher than 60 hz or is it physically incapable of doing so? its an amptron 17 inch CRT... pretty old.
PS - ALSO, IF MY MONITOR IS ONLY REFRESHING AT A FREQUENCY OF 60, DOESN'T THIS MEAN THAT ALTHOUGH MY COUNTER-STRIKE READS 100+ FPS, I'M NOT TRULY SEEING THOSE 100 FRAMES IN A SECOND??
Update your monitor drivers? It's possible your monitor can't go above a certain Hz.
You were looking at the Viewmeter to see what your "Actually" seeing. For CS you need to look in your game properties: click steam icon > click games > my games > right click counter strike > properties > set launch options > add "-freq 100".
That will make it so when you're playing you'll actually "see" 100fps.
Don't ask how i know all this, muAhahAH
noob with an RS
i poop on you
noob with an RS
earth
wgaede
