compustar alarm problems help!!
grtn316
I just installed a compustar 2wss-as. I have everything hooked up except the clutch bypass. I figured I would test out the basic features and see what happens. This is my first compustar alarm so I am kinda in the blue here. I got the remote to communicate with the brain but it seems that its not working correctly.
1) I started my car to to the tach sensing. it was idling at 1500rpms. i rev'd it a little and now its at 900rpms. I havent started the car in a week but it usually idles around 700. I pushed the tach button and it beeped once. The manual says this is correct. Is the high idle just because it hasnt been started or maybe the wiring?
2) I cant figure out how to arm it. When I push button 1 its supposed to arm/disarm the alarm. When I push this. The display shows the lights flashing and like an arrow pointing up in the window and it does not arm. Do I have the lock wires backwards or something?
Thanks,
UPDATE: If I change it to passive mode, it will lock and unlock the doors. So, for some reason it wont arm.
I disconnected the sensor wire connector and ran a single wire from the connector to the pin on the brain 1 by 1 till i found the faulty sensor. Turned out to be the factory hood pin sensor; bypassed and now works great.
grtn316
grtn316
Midland
grtn316
Mike Mccabe
