running off 75 watts which set do you think is more beneficial/efficient off this amount of power. please don't sugget any other speakers than the one's i list.
speaker A
focal poly glass 165v2
2-way separate
Woofer: 165mm.
Voice Coil: 25mm.
Motor: 84mm.
Tweeter: Tioxyd 5 TN 47.
Filter: 2-way 12dB/octave (adjustable tweeter and midrange level).
Max. power: 150W.
Nom. power: 75W.
Sensitivity: (2,83 V/1m): 93dB.
speaker B
Boston SL60
Nominal Size
6½-inch
Recommended Amplifier Power
80watts RMS-220 watts peak
Nominal Impedance
4 ohm
Frequency Response (3dB in car)
45Hz-22kHz
Sensitivity [1 watt (2.83v) at 1m]
90dB
Mounting Depth
2-7/16" (62.0mm)
System Type
2-way
speaker A
2-way separate
Woofer: 165mm.
Voice Coil: 25mm.
Motor: 84mm.
Max. power: 150W.
Nom. power: 75W.
speaker B
Boston SL60
Nominal Size
6½-inch
Nominal Impedance
4 ohm
45Hz-22kHz
90dB
Mounting Depth
2-7/16" (62.0mm)
System Type
2-way
