hondarider
What would be a good set of components and a decent amp for them for under $300?
each would get 50w @ 4ohms.So when if i had it hooked up correctly would that be a 2 ohm load or a 4 ohm load?
You were doing so well until you typed this. You could bridge it to 200x1 and run a sub, but you can't magically turn a 50x2 amp into a 200x2 amp with the same impedance load.You could bridge it to 200w X 2 But you'd be overpowering them by alot and would probably fry them.
so I messed up on reading the stats. I just glanced at them quickly and responded equally fast without rechecking. Sue meYou were doing so well until you typed this. You could bridge it to 200x1 and run a sub, but you can't magically turn a 50x2 amp into a 200x2 amp with the same impedance load.
Overbudget. Not by much but still overbudget.Rainbow Soundlines from 6spdcoupeAura amp from http://www.partsexpress.com
