component wiring question
conecommander
Pickles
i have the MA Audio MA629C 6 1/2" component set.. my question is regarding the crossover. it has two inputs instead of one, which is different than other crossovers i have used in the past. i am running two component sets off a four channel amp, and running inputs to each tweeter and mid would leave a little short on available channels for my other two speakers. besides just splicing wires and running them to each input (which is how they are now) is there another way to wire these?
huh? ok do you mean you have an positive and negative for the amp. for the tweeter, and mid? there should be there own spot for each of these.
do you have a link to a pic of the crossover?
Did you read the manual? Maybe they just have two inputs to make it easier to connect a bridgeable amp...just a guess. Have you tried using just one of the inputs?
yes i tried only using the woofer and then only tweeter.. will not work unless there is an input to each.. manual shows a picture with a crossover with one input.. MA audio could spend a little more time on their manuals.. they don't do much for the user
conecommander
Pickles
conecommander
Earth
blklegend
