component systems???
surfahbum808
are component systems counted as a total of 4 channels because the tweeters are separate? or do you just count the whole component system woofer and tweeter as a single speaker? so if i had components in the front, and coaxials in the back would i need a 6 channel amp or a 4 channel? HELP!!! //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
each mid + tweet would equal one channel if you are using a passive crossover.. without the crossover, you would need a channel to run each speaker
and odds are you need a 4 channel amp..
almost every prebuilt component set comes with a passive crossover.. coaxs usually have them too, they're usually just hidden or on the side of the speaker, but usually are alot simplier.. (there are exceptions tho)
surfahbum808
surfahbum808
Honolulu, HI
James Bang
