Component speakers not loud
Ok i get it now im going to order a wiring kit tonight and gets these bad boys going.
I dont know if this is the same thing but my friend has a 40w rms amp set up in his car n i wanted to test my speakers out so i hooked em all up and they sound GREAT.
But i was just wondering what just the tweeters would sound like so i unhooked the woofer from the crossover n the tweeters were not that loud. Is this b/c the crossover needs both the tweeters and the woofers for function properly or is it b/c it was just 40w?
Well actually you seen the small part of their potential.. as far I have seen these CDT s handle 90rms.. which is way higher than you friends amp output.. so you will get better sound if you give 80-90rms to these comps...
As for the tweeter... I have no idea.. it might be the charachteristis of cdt s and also amplifier as well.... But a good combination of comp and amp should provide decent and balanced sound in every power spectrum ....
that sucks...
i don't have that problem
those tweeters have to be so over-powering.. i've got some like that on the dash facing the windshield, AND tuned down quite a bit, and they are still pretty ear piercing on rock/metal
it's possibly because you don't know how to tune or aim tweeters...
I can tell you when I got some dynamatting done and the wire from my mid to my 2 way x-over came loose, seemed like my tweeters were playing bass for a brief time before I figured out what was wrong and I was getting alot less volume from them. May be what happened to you, and this would probably give you less volume from them.
warr40
warr40
wantagh ny
warr40
NorthFramingham
    Jun 30, 2026
