component set question
dumple
What's in your trunk?
ok so i took all day to get my component set installed diamond d661s and i go to test them and there is no sound the amp turns on and doesnt go into protect i dont know really much about component sets i just got them and in a trade im pretty sure the ohm loads are ok they are like 5ish on a crappy dmm on the wires that are going to my amp which is a zxi 6406 anybody know someting i dont to why they wont work //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
you can also plug in a tone generator to the inputs on the amp to eliminate the possiblity of the rca's being bad or the head units outputs being bad. if youre amp powers up, most likely its not a voltage issue, but for kicks, you can test the power leads at the amp, remember DC. then the outputs, AC. or if you want to check the outputs on the deck, those are DC as well.
i traded you those component sets.
i got them in a trade but they were sitting in the box since i got them
and never tested them out.
i guarantee everything i sell, we can work something out if it ends up that
the components are bad.
i traded you those component sets. i got them in a trade but they were sitting in the box since i got them
yea its ok im gunna go take a look at them and test another speaker on the amp
shallowfu says it might have a relay stuck so the speakers arnt getting any sound im gunna go see whats up
yea its ok im gunna go take a look at them and test another speaker on the amp shallowfu says it might have a relay stuck so the speakers arnt getting any sound im gunna go see whats up
a relay stuck? in passive crossover? if the amp is turning on, then most likely the outputs on your deck are bad, bad inputs on the amp, bad rca's, bad connection somewhere along the way. for kicks, just switch the rca's from your other amp to this one, just to see if you have any sound at all. keep the volume down.
i switched the rcas from my sub amp and still no output im gunna see what happens when i put the rcas on the rear out put from my deck
if it is the relay thing anyone know where to look for it on a zxi 6406 ?
btw he said it might be stuck becuase of static durring shipping
dumple
dumple
Philly
dumple
