component question
jco1385
expert jcologist
I've been contemplating on what i want to do with my front stage. I have the following equipment:
AMP (Power Acoustik PS4-800 4ch): http://www.dealtime.com/xPF-Power-Acoustik-POWER-ACOUSTIK-POWPS4800-4-CHANNEL-800-WATT-AMPLIFIER
COMPS (Polk MOMO MM6 minus tweets): http://www.polkaudio.com/caraudio/specs/mm6/
TWEETS (Polk MOMO MM400): http://www.polkaudio.com/caraudio/specs/mm400/
I cant decide which would be the best way to run them. I have heard lots of good things about Active vs. Passive, and i think i may want to run them active. The problem comes in when i am trying to figure out which crossovers to use. I know the crossovers that came with the MM6 set are passive. These will not allow me to bi-amp my components. I do have another set of crossovers. They are these: http://mobile.jlaudio.com/products_components.php?comp_id=120 (just the crossovers). These do allow bi-amping. I was thinking that i could use the JL crossovers with my polk speakers, but i am not sure if they will work ok. Should i use the JL crossovers, the MOMO crossovers, or what is another choice? As i have said before, i have never attempted anything such as this, and i'd like to get this done correctly. Thanks for any help.
resurrection...
will an EQX allow me to go active? will it serve as the eq and the x-over, as an all in one deal, rather than an eq and a x-over? i think it will, need some input
jco1385
expert jcologist
jco1385
Mobile, AL
Anniku989
