KyleKidd
Ok well this is my first time setting up my cars audio system.
I'm very confused on how to set up cross-overs and high pass filters.
I really don't know what I'm doing at this point, but i continue to research to try and understand all this.
I'm looking for some guidance
How can i determine what to set them to?
I have:
2x RCF L15 P540's
Specs:
Nominal Basket Diameter - 15"
Impedance - 8 ohms
AES Power Rating - 400 Watts
Program Power 800 Watts
Frequency Response - 50Hz - 2.0kHz
Sensitivity (1W/1m) - 98dB
Voice Coil Diameter - 3" / 76mm
X Damage (peak to peak) - 36mm/1.4"
4x DL10x's
Nominal Basket Diameter - 10"
Impedance - 8 ohms
Power Rating (EIA RS-426A) - 300 Watts
Frequency Response - 100Hz - 2khz
Sensitivity (1W/1m) - 97dB
Voice Coil Diameter - 2.5" / 63.5mm
And 4x Tw46's
Freq Resp: 2 K-25 Khz
400W Peak Power
Sensitivity: 105Db
Imp: 4-8_ /Ferrofluid Enhanced
Powering the system:
1 t10001bd
specs:
Number of Channels 1
Rated Power 500W x 1 @ 4-Ohms
750W x 1 @ 2-Ohms
1000W x 1 @ 1-Ohm
Total Power 1000 Watts
Crossover Controls Low-Pass (LP): 32-250Hz 24db/octave Butterworth
Infrasonic filter: 27Hz 12db/octave
Frequency Response 20Hz to 300Hz +/- 0.5 dB
1x P1400.4 crunch
# 2/3/4 Channel operation
# Power @ 4 Ohm: 700W x 2
# Power @ 2 Ohm: 350W x 4
# Power @ 4 Ohm: 175W x 4
# Number Of Channels: 4
# Maximum Power: 350-1400 Watts
# Built In Crossovers: Yes
and 2x PZi 175.4
# RMS Power Range : 175-500 Watts
# Maximum Power: 1000 Watts
# RMS @ 4-Ohms: 175W x 4-Ch
# RMS @ 2-Ohms: 250W x 4-Ch
# RMS @ 4-Ohms: 500W x 2-Ch
# Crossover Frequency Adjustments: 60 Hz to 1.2kHz
# (30 Hz to 250 Hz Low-Pass)
I have:
2x RCF L15 P540's
Specs:
Impedance - 8 ohms
4x DL10x's
Impedance - 8 ohms
And 4x Tw46's
400W Peak Power
Sensitivity: 105Db
1 t10001bd
specs:
750W x 1 @ 2-Ohms
1000W x 1 @ 1-Ohm
1x P1400.4 crunch
and 2x PZi 175.4
