[Completed] 2 18s ported design
surreal
On my katy perry sht
Design by request for two custom 18" woofers. Specs were provided and 6 cubes a piece proved to work very well for the output the user was looking for.
Enclosure is essentially 12cubes tuned to 30hz, and will work for many others doing two 18s setups.
Dimensions: 48Wx24Tx33D
If you are needing a design for two 18" subwoofers, you can purchase this design for immediate download here: 2x18s Vented enclosure - $15.00 : TheBoxHouse, Enclosure designs
Preference/look, ease of build.. I dont normally do the bottom port unless by request or is needed - either physically, or if absolute help is needed for best extension possible.
Idk I guess my only dip with it is that unless you have a lot of width you really gotta squish the subs in, like you can see the flush baffle is just barely getting the clearance it needs from the edges
It was close for the flush mount but the rest has good clearance.
Oh, and also sometimes using a really wide bottom port make it too skinny and needs to be braced well. Its generally just more work.
surreal
surreal
OK
surreal
