complete plexiglass box
It probably sounds exactly like an MDF enclosure. The only difference would be the density of the plexiglass which wouldn't matter in such an application. Gately Audio has been making boxes for awhile and I have yet to hear one complaint.
Just about all the plexiglass boxes I've seen have used plexi that is too thin. You see, plexiglass is expensive. The thicker it is, the more money it is going to cost. And I hate to say it, but people are cheap. So they use the thin plexi and end up with with a box that flexes terribly.
So basically, if you want performance out of a plexi box, you are going to have to pay for it. You are going to have to pay ALOT for it. Last I knew a sheet with a repectable thickness ran in the $250-$300 range.
Originally posted by JeremyD Just about all the plexiglass boxes I've seen have used plexi that is too thin. You see, plexiglass is expensive. The thicker it is, the more money it is going to cost. And I hate to say it, but people are cheap. So they use the thin plexi and end up with with a box that flexes terribly.
look again then bud. before i lost a lot of hours at work i was going to order a 38x16 sheet of 1" plexi for 160 plus shipping and 3/4" plexi was like 135.
adam
Originally posted by bumpin_blazer look again then bud. before i lost a lot of hours at work i was going to order a 38x16 sheet of 1" plexi for 160 plus shipping and 3/4" plexi was like 135.
adam
38" x 16" is not a sheet. A full sheet is 4' x 8'.
rockford666
rockford666
michigan
JeremyD
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
