I'm not sure about Pyle brand, anyone have anything to write about it? I need a upgrade, I'm thiking on getting a PLAD3300D Pyle
Pyle (PLAD3300D) 3600 Watt Mono Block MOSFET Digital Amplifier
Specifications:
* 1x600W RMS at 4 Ohms
* 1x1800W RMS at 2 Ohms
* 1x3600W MAX at 1.3 Ohms
* Mono Block Subwoofer Amplifier
* 1 Ohm Stereo Stable
* MOSFET Power Supply
* PWM (Pulse-Width-Modulated) System
* Double Sided Epoxy PCB Circuit Board
* Gold Plated RCA Inputs
* Custom Terminal Block for Speaker Connections
* Thermal, Overload & Short Protection
* Variable Low pass Filter (50Hz~150Hz,24dB/Octave)
* Variable Subsonic Filter (15Hz~40Hz,24dB/Octave)
* Phase Control 0-180 Degree
* Remote Bass Level Control
* Input Impedance:10K Ohms
* Soft Turn-on/Turn-off
* Red Lighting Illumination
* Side Leg Mounting
* THD:
* S/N Ratio: >90dB
* Input Sensitivity : 200mV ~8V
* Freq. Response : 15Hz ~ 150KHz
* Patent Pending
* Heavy Duty Power Coated Heatsink
* Dimensions : 8.6''(W) x 2.74''(H) x 15''(L)
http://www.pyleaudio.com/itemdetail.asp?model=PLAD3300D
Specifications:
* Side Leg Mounting
* THD:
* S/N Ratio: >90dB
* Patent Pending
