Same RMS at different ohms...
Mugen
Superhero.
Why do some amps do this (I've noticed it mainly among JL/Alpine)? If the thing can push 1000w @ 4ohms, why do they limit it to 1000w @ 1ohm? Shouldn't be able to easily push more than that? Is it considered a "feature"? Honestly, if I was spending $800 on a 1000/1, I'd expect more than 1000w //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Yes, the company considers it a feature/benefit.
Their mentality is that it is a benefit to the consumer because it allows them to choose virtually any subwoofer(s) without having to worry so much about "matching" it to the amplifier or receiving a decreased level of power output from the amplifier at a given impedance. You can have a final impedance of anywhere between 1ohm (1.5ohm on the JL) and 4ohm and still receive approximately 1kw of output, instead of only having 250w @ 4ohm, 500w @ 2ohm and 1kw only at 1ohm.
Many like this feature....others don't.....it's all personal opinion.
I am curious how fast this "feature" reacts. Since impedance changes with frequency it looks as thought this would be a benefit as it would maintain a consistant RMS over a longer durartion (in say a sweep)
There are pros/cons to 'power regulating' amplifiers vs. regular amp.
Regular amp
Lets say you bought a 1000w @ 1 ohm amplifier and used your favorite 1 ohm
woofer. All is good, the woofer gets 1000w.
Later you added another 1 ohm woofer and the only wiring option is 2 ohms.
The amp will output 500w @ 2 ohms and each of your woofers gets 250w.
Power regulating amp
You have 1000w @ 1 ohm, you add another 1 ohm woofer in series for 2 ohms
and you get 500w per woofer.
On the other hand, you have a 1000w @ 4 ohm woofer. You upgrade
and add another 4 ohm woofer in parallel. The regular amp has potential
to output 2000w @ 2 ohms, 1000w per woofer, whereas the power regulating
amp only outputs 1000w, 500w per woofer.
This JL design has multiple voltage rails.
http://www.carsound.com/review_archive/amps/jl_3004.html
The 300/4 has three voltage rails. The claim is that current sensing causes
rail switching. This type of design won't be exact.
Another design may detect the impedance at power up and then just rail
switch one time.
I think it's a pretty cool feature. I think the PG Xenon amps are that way too.
The only reason I think it's dumb is because it's limiting potential power the amp could put out. I guess if you need an amp to push 4ohms, it's good. But if you have a 1ohm load, I wouldn't touch those "restricted" amps, seems like a waste of cash.
x2 you may have a 1ohm sub but after box rise you may only be gettin the 2ohm rating on the amp I think its a great feature just wish they could put that on Big amps //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
x2........im bored get on aim..lol....//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'm not following your logic?
If you need 1kw @ 1ohm, what's wrong with an amp that does 1kw @ 1ohm and 1kw at higher impedances aswell?
If you needed substantially more than 1kw @ 1ohm...then you wouldn't be looking at this amp in the first place so it's a moot point.
The value of dollars per watt is entirely relative //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Genesis and Brax continue to sell amps...
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Mugen
Superhero.
Mugen
Walker, LA
helotaxi
