they regularly come with birthsheets near a thousand watts. I expect an amp that's **** near 2 ft long to have a reason to be this physically large. you open up an old rf amp capable of a thousand watts, and you see it packed full of electronics. this is just... big for the sake of big. add to it that it was a special edition "flagship" product, and its dissapointing.Well these are rated 75x2 @4ohm. So I'm not really sure what you were hoping for. They do test out at more like 300x2@4
valuable input, thank you. I just wish, with this amount of circuitry, it could have a smaller footprint.circuit design isn't as straightforward as more components = better and more stable power
there's A LOT more to it. in fact, a simpler design is ideal, it has more efficiency, less noise, and less components to fail over time. on top of that, if its a 'beefy' amplifier with a bunch of components in a small case it wont dissipate heat properly when compared to a better simple design that produces the same power with less components, there's going to be less heat.
the hardest thing to do with circuits is simplify and reduce them, anyone can go copy another board and put their **** on it. improving a design and reducing its complexity (or increasing complexity, provided the goal necessitates it) is much more realistic than simply adding more **** so people think its a beefy amp
yup, its complete and fully functional, as it left the factory.Does that picture have all the parts on the board? It looks like it can have 4 more big caps on it. Has a outline for them to go there
hope so //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifThis thing will definately **** some components
