Coil is stuck in gap, help!!!! broke in 2
da box king
Well I'm tearing apart my hdc3 that had coil rub, and well the housing that the coil is wrapped around broke in 2 pieces....and the bottem end is stuck around the pole with the other end of the coil windings. I didn't even pull on it, I took it out, and the coil housing was broke in 2 pieces....no how the hell can I get the coil out. I've tugged on the coil but that thing aint comin:(
nobodys gonna what to buy that sub for that price with the coil stuck in the bottom of the motor,sorry.
i have fixed these before but it takes some time. get a metal coat hanger cut it so you have a strait piece then take linemans pliers and bend the other end in a VERY short L and keep working it out piece by piece.
it's very possible it fugged up the pole...
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
another hdc3 with a coil that fell apart. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
nope got it guys.....was easy actually...and **** the glue dj gave me really didn't seem too strong
I hit the spider landing once with a hammer and the whole thing pretty much came off, and out came the rest of the coil with a hammer. and also I could peel the surround off with my fingers...someone want to explain why this $30 glue did this? and yes there was enough glue....MikeyB did em for me, was spread around evenly....also when I tore the surround off some spots came off clean leaving bare metal...the glue came right off...wtf
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifanother hdc3 with a coil that fell apart. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
what do you mean by this too? just curious, have you heard somethin PAP?//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
to check the pole just slide a piece of feeler stock or something small and feel for burrs. dont tell me u used ca glue for the surronds? use goop or a thick contact cement...
glad u got it out of there.
how did the coil rock enough for the fromer to break in 2? did you have a couple spiders come apart?
It sounds like the basket was cleaned and de-greased properly.However I have been told that the glue holding down the surrond only has to be a good contact cement to hold it properly and makes clening easier when reconing.
just my .02
well I did the glue to dj's specs...as for the coil, I'm not sure why it did that. the spiders were fine...but I did hook it up to the 120 outlet to end its life...it still worked after about 15 sec, but the breaker kept flipping....the coil was just starting to seperate
da box king
da box king
Portland, MI
SPLaudio
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
