Coaxials/Component sets, for under $150.
Plutoman
<-- Yes, that's me.
What's good options here?
Looking for two sets - front stage and rear fill - yes, I want the rear fill, I have passengers in the back nearly all the time, for about $150 total. *Maybe* as high as $200. Unlikely though - I'd probably have to kill plans for a sub - and that'd increase my budget to around $300, but I'd have no full bass to go along.
Front is 4x6 space, back is 6.75" space for what I'm looking at. This is for future, about a month down the line, so any offers from people personally are probably a no.
It'd be good to have some low frequency extension for the midbass, and I'll put up to and around 55 RMS through each.
I highly doubt you'll find a 4x6 comp set. You'll have to make a 6.5" set fit which shouldn't be a problem.
I like the Polk dB651 comps with matching coax's, but that's around $200 total.
Hmmm. Probably likely - best best would probably be two sets of the PG components. Right around my power range, cheap, decent. Gives me $30 extra dollars to put into a bass system.
You can get a 4" comp set and make a 4x6" plate and mount the tweeter next to the 4" mid, this will sound better than a coax. If you have to stick with a 4" coax the CTX4's are a great suggestion.
http://www.techronics.com/index.cfm?fuseaction=product.display&amp;Product_ID=8396. Here's a good amp at a very good price. Let me know what u think about the budget system I got picked out.
That's up to $550 without a subwoofer. $700 or so with one. Not a budget system -.-
I already had a ZX750.1. Sold it. Getting a smaller subwoofer, I'm looking at a good sound quality, with a shallow mount sub, powered by a small amp, with an entire setup minus head unit and comp amp for $400. Which means budget components. Not ID and JL everything. Please.
Not only that, but I had two 12w3's too, and if I reconed those, it'd be good. But, I DON'T want those -.-
I'm going to go ahead and modify the area. I want the low frequency extension of a 6.5" compared to the 4x6, so if I can't properly mount then, I'll make myself a mount for them on the doors.
Plutoman
<-- Yes, that's me.
Plutoman
Kansas City
Plutoman
