would be alright its dependable you can get us acoustics and coustic pretty cheap on line as wellim going to keep a pair of my coaxs for now, but would the Profile AP400 amp work for my pair of Alpine type S speakers. The speakers are rated at 45wrms and the amp is rated at 65wrms x 2 at 4 ohms and 100wrms x 2 at 2 ohms, do the Profile amps acutually put out their rated RMS or will my speakers be fine?
bout to get a 2 channel amp from a friend and want to know if what im bout to do is right. (better safe then sorry)
no particular order:
RCAs from HU to amp
power wire from battery to amp
Gound amp to car chassis
REM from HU to amp
Speaker wire from amp to coaxs (tape off speaker wire in car door since im not running them off HU)
if i forgot anything LMK
BTW, I already have a BX1000D hooked up, is there anything special i might need since im going to have a 2 amp setup? Also, do I just connect both rems from each amp and connect them to the HU?
THANKS
You can, but since they are already disconnected at the other end of the wires, you don't have to.When I tape off the wire in my door do i also disconnect the front left and right speaker connections from my HU and tape those off since they are not going to be running off my HU, or do i need to keep those connected? I fugure i do but not 100%
