martinezaudio06
so is clipping putting to much power to a sub? im not sure what it means? help?
you can make your amp or cd player clip as long as your speakers can handle it cause a clipped signal is like 2x the power
so if you have a 500 watt amp and clip the hell out of it, it could be like 1000 watts
im using a 600 watt amp and clip the hell out of it but my sub can handle 1200+
i wouldnt do that with your mids and highs, it will probably sound bad but with a sub, you cant hear it
are they wired correctly, are they moving muchi see cuz i have the two earthquake subzero subs which use fuses in the terminals and it was blowing the fuses in one of the subs and they were getting pretty warm after only a couple of minutes
it will get louder, i have a $3000 spl meter and scope to prove it , sounds fine to meyou should have it set for your system to not clip at all...your not getting any more power and it just sounds like crap.
turn your gains/bassboost down
i have never heard of anyone wanting to turn there amp up above clipping...it will get louder, i have a $3000 spl meter and scope to prove it , sounds fine to me
General Radio 1565-A (made in the 60's iirc)wth kind of spl meter did you get for 3000?tl's only cost like 800...
